Disconnect in Hidden SSID!! (ZD1100, F/W : 9,4)
Hi~.
I recevied issue from customer.
It's disconnect issue when hidden ssid enabled.
Why happend the issue?
ZD F/W is 9.4, model is ZD1100.
APs are 6 of ZF7363
The following is client log.
Thanks.
Jul 17 17:44:15 ruckus syslog: logXdataImpl(): Jul 17 17:44:16 ruckus stamgr: stamgr_fltlog_set_mac():set filtering mac 7c:7a:91:48:60:02
Jul 17 17:41:19 ruckus stamgr: handle_frame():received mgmt frame type from 7c:7a:91:48:60:02 to AP (58:93:96:d5:f6:dc)
Jul 17 17:41:19 ruckus stamgr: ieee802_11_mgmt():VAP 58:93:96:d5:f6:dc- received mgmt auth frame from 7c:7a:91:48:60:02
Jul 17 17:41:19 ruckus stamgr: handle_auth():VAP 58:93:96:d5:f6:dc- authentication: STA=7c:7a:91:48:60:02
Jul 17 17:41:19 ruckus stamgr: handle_auth():VAP 58:93:96:d5:f6:dc- authentication: STA=7c:7a:91:48:60:02 auth_alg=0000000000 auth_transaction=0x00000001 status_code=0000000000 wep=0
Jul 17 17:41:19 ruckus stamgr: ap_sta_add():VAP 58:93:96:d5:f6:dc- allocate a new STA entry for 7c:7a:91:48:60:02
Jul 17 17:41:19 ruckus stamgr: stamgr_init_STA(): 7c:7a:91:48:60:02 multi-sessid [589396d5f6dc7c7a9148600255a8bfafc891], len 36
Jul 17 17:41:19 ruckus stamgr: handle_auth():VAP 58:93:96:d5:f6:dc- STA 7c:7a:91:48:60:02 (ref_cnt=1) authentication OK (open system)
Jul 17 17:41:19 ruckus stamgr: handle_auth():VAP 58:93:96:d5:f6:dc- STA 7c:7a:91:48:60:02 Open AUTH success: ZD does not need to send auth reply.
Jul 17 17:41:19 ruckus stamgr: ieee802_11_mgmt():VAP 58:93:96:d5:f6:dc- received mgmt assoc req frame from 7c:7a:91:48:60:02
Jul 17 17:41:19 ruckus stamgr: handle_assoc():VAP 58:93:96:d5:f6:dc- STA 7c:7a:91:48:60:02  association request,  capab_info=0x411 listen_interval=250
Jul 17 17:41:19 ruckus stamgr: wpa_validate_wpa_ie():STA 7c:7a:91:48:60:02 lookup_cache 1, is_roaming 0, pmk_for_reconnect 1, num_pmkid 1
Jul 17 17:41:19 ruckus stamgr: handle_assoc():VAP 58:93:96:d5:f6:dc- STA 7c:7a:91:48:60:02: WMM parameters: wmm ie len=7 version=1, qos=000000
Jul 17 17:41:19 ruckus stamgr: handle_assoc():VAP 58:93:96:d5:f6:dc- STA 7c:7a:91:48:60:02: htcap_ie len=26
Jul 17 17:41:19 ruckus stamgr: handle_assoc():VAP 58:93:96:d5:f6:dc- STA 7c:7a:91:48:60:02 (ref_cnt=2)  associates OK, AID=1
Jul 17 17:41:19 ruckus stamgr: eapol_sm_alloc():7c:7a:91:48:60:02 aaa flags 0
Jul 17 17:41:19 ruckus stamgr: eapol_sm_alloc():7c:7a:91:48:60:02 run eap
Jul 17 17:41:19 ruckus stamgr: sm_AUTH_PAE_INITIALIZE_Enter():802.1x: 7c:7a:91:48:60:02 AUTH_PAE enters INITIALIZE
Jul 17 17:41:19 ruckus stamgr: sm_BE_AUTH_INITIALIZE_Enter():802.1x: 7c:7a:91:48:60:02 BE_AUTH enters INITIALIZE
Jul 17 17:41:19 ruckus stamgr: sm_REAUTH_TIMER_INITIALIZE_Enter():802.1x: 7c:7a:91:48:60:02 REAUTH_TIMER enters INITIALIZE
Jul 17 17:41:19 ruckus stamgr: sm_AUTH_KEY_TX_NO_KEY_TRANSMIT_Enter():802.1x: 7c:7a:91:48:60:02 AUTH_KEY_TX enters NO_KEY_TRANSMIT
Jul 17 17:41:19 ruckus stamgr: sm_KEY_RX_NO_KEY_RECEIVE_Enter():802.1x: 7c:7a:91:48:60:02 KEY_RX enters NO_KEY_RECEIVE
Jul 17 17:41:19 ruckus stamgr: sm_CTRL_DIR_IN_OR_BOTH_Enter():802.1x: 7c:7a:91:48:60:02 CTRL_DIR enters IN_OR_BOTH
Jul 17 17:41:19 ruckus stamgr: sm_BE_AUTH_IDLE_Enter():802.1x: 7c:7a:91:48:60:02 BE_AUTH enters IDLE
Jul 17 17:41:19 ruckus stamgr: sm_CTRL_DIR_FORCE_BOTH_Enter():802.1x: 7c:7a:91:48:60:02 CTRL_DIR enters FORCE_BOTH
Jul 17 17:41:19 ruckus stamgr: eapol_port_timers_schedule():802.1x: 7c:7a:91:48:60:02 schedule timeout=1, aWhile=0, quietWhile=0, reAuthWhen=36000
Jul 17 17:41:19 ruckus stamgr: stamgr_handle_add_remote_sta_reply():Receive add remote sta 7c:7a:91:48:60:02 reply
Jul 17 17:41:20 ruckus stamgr: eapol_port_timers_update_elapse():802.1x: 7c:7a:91:48:60:02 min_timeout=1 reload=0 elapse=1 timer_reset=0x0, aWhile=0, quietWhile=0, reAuthWhen=36000
Jul 17 17:41:20 ruckus stamgr: sm_AUTH_PAE_DISCONNECTED_Enter():802.1x: 7c:7a:91:48:60:02 AUTH_PAE enters DISCONNECTED
Jul 17 17:41:20 ruckus stamgr: ieee802_1x_set_sta_authorized():VAP 58:93:96:d5:f6:dc- unauthorizing port for STA 7c:7a:91:48:60:02
Jul 17 17:41:20 ruckus stamgr: sm_REAUTH_TIMER_INITIALIZE_Enter():802.1x: 7c:7a:91:48:60:02 REAUTH_TIMER enters INITIALIZE
Jul 17 17:41:20 ruckus stamgr: sm_AUTH_PAE_RESTART_Enter():802.1x: 7c:7a:91:48:60:02 AUTH_PAE enters RESTART
Jul 17 17:41:20 ruckus stamgr: sm_AUTH_PAE_CONNECTING_Enter():802.1x: 7c:7a:91:48:60:02 AUTH_PAE enters CONNECTING
Jul 17 17:41:20 ruckus stamgr: sm_AUTH_PAE_AUTHENTICATING_Enter():802.1x: 7c:7a:91:48:60:02 AUTH_PAE enters AUTHENTICATING
Jul 17 17:41:20 ruckus stamgr: sm_BE_AUTH_REQUEST_Enter():802.1x: 7c:7a:91:48:60:02 BE_AUTH enters REQUEST
Jul 17 17:41:20 ruckus stamgr: ieee802_1x_send():VAP 58:93:96:d5:f6:dc- Sending EAPOL packet to 7c:7a:91:48:60:02
Jul 17 17:41:20 ruckus stamgr: eapol_port_timers_update_elapse():802.1x: 7c:7a:91:48:60:02 min_timeout=0 reload=1 elapse=1 timer_reset=0x4, aWhile=0, quietWhile=0, reAuthWhen=36000
Jul 17 17:41:20 ruckus stamgr: eapol_port_timers_schedule():802.1x: 7c:7a:91:48:60:02 schedule timeout=36000, aWhile=0, quietWhile=0, reAuthWhen=36000
Jul 17 17:41:20 ruckus stamgr: handle_frame():received data frame type from 7c:7a:91:48:60:02 to AP (58:93:96:d5:f6:dc) len=41
Jul 17 17:41:20 ruckus stamgr: ieee802_1x_receive():VAP 58:93:96:d5:f6:dc-  received EAPOL packet (5 bytes) from STA 7c:7a:91:48:60:02, ref_cnt=2
Jul 17 17:41:20 ruckus stamgr: ieee802_1x_receive():VAP 58:93:96:d5:f6:dc-  received EAPOL packet with extra 1 bytes  from STA 7c:7a:91:48:60:02, expected len = 4
Jul 17 17:41:20 ruckus stamgr: ieee802_1x_receive():VAP 58:93:96:d5:f6:dc- received EAPOL-start from STA 7c:7a:91:48:60:02
Jul 17 17:41:20 ruckus stamgr: ieee802_1x_receive():7c:7a:91:48:60:02 normal eapol-start
Jul 17 17:41:20 ruckus stamgr: eapol_port_timers_update_elapse():802.1x: 7c:7a:91:48:60:02 min_timeout=36000 reload=1 elapse=0 timer_reset=0x0, aWhile=0, quietWhile=0, reAuthWhen=36000
Jul 17 17:41:20 ruckus stamgr: eapol_port_timers_schedule():802.1x: 7c:7a:91:48:60:02 schedule timeout=1, aWhile=0, quietWhile=0, reAuthWhen=36000
Jul 17 17:41:20 ruckus stamgr: sm_AUTH_PAE_ABORTING_Enter():802.1x: 7c:7a:91:48:60:02 AUTH_PAE enters ABORTING
Jul 17 17:41:20 ruckus stamgr: sm_BE_AUTH_INITIALIZE_Enter():802.1x: 7c:7a:91:48:60:02 BE_AUTH enters INITIALIZE
Jul 17 17:41:20 ruckus stamgr: sm_BE_AUTH_IDLE_Enter():802.1x: 7c:7a:91:48:60:02 BE_AUTH enters IDLE
Jul 17 17:41:20 ruckus stamgr: handle_frame():received data frame type from 7c:7a:91:48:60:02 to AP (58:93:96:d5:f6:dc) len=49
Jul 17 17:41:20 ruckus stamgr: ieee802_1x_receive():VAP 58:93:96:d5:f6:dc-  received EAPOL packet (13 bytes) from STA 7c:7a:91:48:60:02, ref_cnt=2
Jul 17 17:41:20 ruckus stamgr: handle_eap():VAP 58:93:96:d5:f6:dc-  received EAP packet from STA 7c:7a:91:48:60:02, code=2, id=55  len=9
Jul 17 17:41:20 ruckus stamgr: handle_eap_response():VAP 58:93:96:d5:f6:dc- Mismatched identifier in Respond-Identity  from STA 7c:7a:91:48:60:02(should be 227, got 55)
Jul 17 17:41:20 ruckus stamgr: handle_eap():VAP 58:93:96:d5:f6:dc-  received EAP packet from STA 7c:7a:91:48:60:02, code=2, id=227  len=9
Jul 17 17:41:20 ruckus stamgr: handle_eap_response():VAP 58:93:96:d5:f6:dc- Received EAP packet, code=2, id = 227, len = 9, from STA 7c:7a:91:48:60:02 Reponse-Identity
Jul 17 17:41:20 ruckus stamgr: sm_BE_AUTH_RESPONSE_Enter():802.1x: 7c:7a:91:48:60:02 BE_AUTH enters RESPONSE
Jul 17 17:41:20 ruckus stamgr: handle_frame():received data frame type from 7c:7a:91:48:60:02 to AP (58:93:96:d5:f6:dc) len=145
Jul 17 17:41:20 ruckus stamgr: ieee802_1x_receive():VAP 58:93:96:d5:f6:dc-  received EAPOL packet (109 bytes) from STA 7c:7a:91:48:60:02, ref_cnt=2
Jul 17 17:41:20 ruckus stamgr: handle_eap():VAP 58:93:96:d5:f6:dc-  received EAP packet from STA 7c:7a:91:48:60:02, code=2, id=228  len=105
Jul 17 17:41:20 ruckus stamgr: handle_eap_response():VAP 58:93:96:d5:f6:dc- Received EAP packet, code=2, id = 228, len = 105, from STA 7c:7a:91:48:60:02 Reponse-PEAP
Jul 17 17:41:20 ruckus stamgr: handle_frame():received data frame type from 7c:7a:91:48:60:02 to AP (58:93:96:d5:f6:dc) len=46
Jul 17 17:41:20 ruckus stamgr: ieee802_1x_receive():VAP 58:93:96:d5:f6:dc-  received EAPOL packet (10 bytes) from STA 7c:7a:91:48:60:02, ref_cnt=2
Jul 17 17:41:20 ruckus stamgr: handle_eap():VAP 58:93:96:d5:f6:dc-  received EAP packet from STA 7c:7a:91:48:60:02, code=2, id=229  len=6
Jul 17 17:41:20 ruckus stamgr: handle_eap_response():VAP 58:93:96:d5:f6:dc- Received EAP packet, code=2, id = 229, len = 6, from STA 7c:7a:91:48:60:02 Reponse-PEAP
Jul 17 17:41:20 ruckus stamgr: handle_frame():received data frame type from 7c:7a:91:48:60:02 to AP (58:93:96:d5:f6:dc) len=248
Jul 17 17:41:20 ruckus stamgr: ieee802_1x_receive():VAP 58:93:96:d5:f6:dc-  received EAPOL packet (212 bytes) from STA 7c:7a:91:48:60:02, ref_cnt=2
Jul 17 17:41:20 ruckus stamgr: handle_eap():VAP 58:93:96:d5:f6:dc-  received EAP packet from STA 7c:7a:91:48:60:02, code=2, id=230  len=208
Jul 17 17:41:20 ruckus stamgr: handle_eap_response():VAP 58:93:96:d5:f6:dc- Received EAP packet, code=2, id = 230, len = 208, from STA 7c:7a:91:48:60:02 Reponse-PEAP
Jul 17 17:41:21 ruckus stamgr: handle_frame():received data frame type from 7c:7a:91:48:60:02 to AP (58:93:96:d5:f6:dc) len=46
Jul 17 17:41:21 ruckus stamgr: ieee802_1x_receive():VAP 58:93:96:d5:f6:dc-  received EAPOL packet (10 bytes) from STA 7c:7a:91:48:60:02, ref_cnt=2
Jul 17 17:41:21 ruckus stamgr: handle_eap():VAP 58:93:96:d5:f6:dc-  received EAP packet from STA 7c:7a:91:48:60:02, code=2, id=231  len=6
Jul 17 17:41:21 ruckus stamgr: handle_eap_response():VAP 58:93:96:d5:f6:dc- Received EAP packet, code=2, id = 231, len = 6, from STA 7c:7a:91:48:60:02 Reponse-PEAP
Jul 17 17:41:21 ruckus stamgr: sm_BE_AUTH_RESPONSE_Enter():802.1x: 7c:7a:91:48:60:02 BE_AUTH enters RESPONSE
Jul 17 17:41:21 ruckus stamgr: sm_REAUTH_TIMER_INITIALIZE_Enter():802.1x: 7c:7a:91:48:60:02 REAUTH_TIMER enters INITIALIZE
Jul 17 17:41:21 ruckus stamgr: sm_BE_AUTH_REQUEST_Enter():802.1x: 7c:7a:91:48:60:02 BE_AUTH enters REQUEST
Jul 17 17:41:21 ruckus stamgr: ieee802_1x_send():VAP 58:93:96:d5:f6:dc- Sending EAPOL packet to 7c:7a:91:48:60:02
Jul 17 17:41:21 ruckus stamgr: handle_frame():received data frame type from 7c:7a:91:48:60:02 to AP (58:93:96:d5:f6:dc) len=83
Jul 17 17:41:21 ruckus stamgr: ieee802_1x_receive():VAP 58:93:96:d5:f6:dc-  received EAPOL packet (47 bytes) from STA 7c:7a:91:48:60:02, ref_cnt=2
Jul 17 17:41:21 ruckus stamgr: handle_eap():VAP 58:93:96:d5:f6:dc-  received EAP packet from STA 7c:7a:91:48:60:02, code=2, id=232  len=43
Jul 17 17:41:21 ruckus stamgr: handle_eap_response():VAP 58:93:96:d5:f6:dc- Received EAP packet, code=2, id = 232, len = 43, from STA 7c:7a:91:48:60:02 Reponse-PEAP
Jul 17 17:41:21 ruckus stamgr: handle_frame():received data frame type from 7c:7a:91:48:60:02 to AP (58:93:96:d5:f6:dc) len=131
Jul 17 17:41:21 ruckus stamgr: ieee802_1x_receive():VAP 58:93:96:d5:f6:dc-  received EAPOL packet (95 bytes) from STA 7c:7a:91:48:60:02, ref_cnt=2
Jul 17 17:41:21 ruckus stamgr: handle_eap():VAP 58:93:96:d5:f6:dc-  received EAP packet from STA 7c:7a:91:48:60:02, code=2, id=233  len=91
Jul 17 17:41:21 ruckus stamgr: handle_eap_response():VAP 58:93:96:d5:f6:dc- Received EAP packet, code=2, id = 233, len = 91, from STA 7c:7a:91:48:60:02 Reponse-PEAP
Jul 17 17:41:21 ruckus stamgr: handle_eap():VAP 58:93:96:d5:f6:dc-  received EAP packet from STA 7c:7a:91:48:60:02, code=2, id=234  len=43
Jul 17 17:41:21 ruckus stamgr: handle_eap_response():VAP 58:93:96:d5:f6:dc- Received EAP packet, code=2, id = 234, len = 43, from STA 7c:7a:91:48:60:02 Reponse-PEAP
Jul 17 17:41:21 ruckus stamgr: handle_eap():VAP 58:93:96:d5:f6:dc-  received EAP packet from STA 7c:7a:91:48:60:02, code=2, id=235  len=43
Jul 17 17:41:21 ruckus stamgr: handle_eap_response():VAP 58:93:96:d5:f6:dc- Received EAP packet, code=2, id = 235, len = 43, from STA 7c:7a:91:48:60:02 Reponse-PEAP
Jul 17 17:41:21 ruckus stamgr: sm_BE_AUTH_SUCCESS_Enter():802.1x: 7c:7a:91:48:60:02 BE_AUTH enters SUCCESS
Jul 17 17:41:21 ruckus stamgr: sm_BE_AUTH_IDLE_Enter():802.1x: 7c:7a:91:48:60:02 BE_AUTH enters IDLE
Jul 17 17:41:21 ruckus stamgr: wpa_send_eapol():VAP 58:93:96:d5:f6:dc- EAPOL-Key to STA 7c:7a:91:48:60:02pairwise = true, alg = 16
Jul 17 17:41:21 ruckus stamgr: handle_frame():received data frame type from 7c:7a:91:48:60:02 to AP (58:93:96:d5:f6:dc) len=175
Jul 17 17:41:21 ruckus stamgr: ieee802_1x_receive():VAP 58:93:96:d5:f6:dc-  received EAPOL packet (139 bytes) from STA 7c:7a:91:48:60:02, ref_cnt=2
Jul 17 17:41:21 ruckus stamgr: handle_frame():received data frame type from 7c:7a:91:48:60:02 to AP (58:93:96:d5:f6:dc) len=135
Jul 17 17:41:21 ruckus stamgr: ieee802_1x_receive():VAP 58:93:96:d5:f6:dc-  received EAPOL packet (99 bytes) from STA 7c:7a:91:48:60:02, ref_cnt=2
Jul 17 17:41:21 ruckus stamgr: stamgr_sta_notify_session_key():send sta (7c:7a:91:48:60:02) key update to remote AP:
Jul 17 17:41:21 ruckus stamgr: stamgr_handle_set_param_sta_reply():Receive STAMGR_SET_STA_PARAM/STAMGR_SET_STA_KEY 7c:7a:91:48:60:02 reply
Jul 17 17:41:21 ruckus stamgr: eapol_port_timers_update_elapse():802.1x: 7c:7a:91:48:60:02 min_timeout=1 reload=0 elapse=1 timer_reset=0x5, aWhile=30, quietWhile=0, reAuthWhen=36000
Jul 17 17:41:21 ruckus stamgr: sm_AUTH_PAE_AUTHENTICATED_Enter():802.1x: 7c:7a:91:48:60:02 AUTH_PAE enters AUTHENTICATED
Jul 17 17:41:21 ruckus stamgr: ieee802_1x_set_sta_authorized():VAP 58:93:96:d5:f6:dc- authorizing port for STA 7c:7a:91:48:60:02
Jul 17 17:41:21 ruckus stamgr: ieee802_1x_set_sta_authorized():VAP 58:93:96:d5:f6:dc- adding station 7c:7a:91:48:60:02 to user qwer
Jul 17 17:41:21 ruckus stamgr: sm_AUTH_PAE_AUTHENTICATED_Enter():eapol: 7c:7a:91:48:60:02 authenticated on VAP 58:93:96:d5:f6:dc
Jul 17 17:41:21 ruckus stamgr: eapol_port_timers_update_elapse():802.1x: 7c:7a:91:48:60:02 min_timeout=0 reload=1 elapse=1 timer_reset=0x0, aWhile=30, quietWhile=0, reAuthWhen=36000
Jul 17 17:41:21 ruckus stamgr: eapol_port_timers_schedule():802.1x: 7c:7a:91:48:60:02 schedule timeout=29, aWhile=29, quietWhile=0, reAuthWhen=35999
Jul 17 17:41:21 ruckus syslog: eventd_to_syslog():User[qwer@7c:7a:91:48:60:02] joins WLAN[test1] from AP[RnD-6F-AP-02@58:93:96:15:f6:d0]
Jul 17 17:41:29 ruckus stamgr: tac_send_remote_sta_delete():send del sta (7c:7a:91:48:60:02) to remote AP w elmt_id=0xb radio=1, wlan id=3
Jul 17 17:41:29 ruckus stamgr: tac_remote_sta_remove():send del sta (7c:7a:91:48:60:02)to remote AP
Jul 17 17:41:29 ruckus syslog: eventd_to_syslog():User[qwer@7c:7a:91:48:60:02] disconnected by admin from WLAN[test1] at AP[RnD-6F-AP-02@58:93:96:15:f6:d0]
Jul 17 17:41:29 ruckus stamgr: acsrvc_thread():ACSRVC receives IPC message from module LWAPP for msg Station Last Stats (0x600001b) from sta 7c:7a:91:48:60:02, VAP 58:93:96:d5:f6:dc
Jul 17 17:41:29 ruckus stamgr: stamgr_handle_remote_sta_leave():Cannot delete STA 7c:7a:91:48:60:02 not found on VAP 58:93:96:d5:f6:dc
Jul 17 17:43:43 ruckus stamgr: stamgr_handle_get_sta_stat():Receive a GET-STA mssage, id=7c:7a:91:48:60:02
Regards.
4 REPLIES 4
