Disable Wireless Network - Radiation?
marco_eichstet1
Contributor III
because on of my APs is located in the bedroom i want to schedule Wireless Network Broadcast with Unleashed GUI to turn off all Wireless Networks at night.
If i schedule all Networks to be disabled at night, will the Antennas be off with no Wireless Radiation?
Thanks and KR
Marco
6 REPLIES 6
Richard is right - guess what, that LTE Radio on that cell phone in your pocket is 20x stronger than what any certified WiFi equipment is capable of 😉
sam_ogra
Well, even cellphone emit small amount of radiaiton but not enough to kill us, though we are holding to them almost all the time. But if you are that worried you can check radiation with dosimeter like https://ecotestgroup.com/products/mks-um/ .
