04-21-2023 02:33 PM
I have the status LEDs disabled on our r650 and r750 access points, but is there any way to disable the Ethernet LEDs as well? The flashing lights appear quite bright in a dark room, and serve no real purpose up on the ceiling.
If there is no way to turn them off, can I put in an enhancement request in to have them turned off along side the status LEDs?
05-26-2023 02:16 PM
Ping
05-28-2023 10:46 PM
Hi @dennypage
I had a check on this internally. We do not have option to disable this feature.
You can contact our support line to see if you can get any SE contact details. You can check if you can raise the feature request from there.
