Convert R500 Unleashed to ZD managed?
brian_hoyt_6612
Contributor
I could find some posts about this but most were 2+ years old. I wanted to check what current guidance on this is? I have two R500 Unleashed that I was using at remote site. I now want to bring them into main site under my ZD1200 to be normal managed AP. Do I still manually upgrade firmware? If so which one? Or can my 9.13 ZD1200 adopt them somehow? Thanks.
5 REPLIES 5
If the AP is in same L2 domain as controller, it will find controller by bcast/mcast methods. If controller is across/another L2 network, use DHCP option 43 to adopt. If you cant do DHCP options, login to webgui to set controller IP with static method.
HTH
Karthik.
Karthik.
