03-15-2016 08:30 AM
We tried
· DHCP option 43 as described in https://support.ruckuswireless.com/answers/000003197
· manually add the director ip (set director ip x.x.x.x) on the ap
but the AP doesn’t connect and/or perform no firmware update.
When we first connect the AP internally to the vSZ and move the AP to the appropriate Zone, it will work at the customer ́s Network.
Did we miss something or doing it wrong?
03-15-2016 09:30 AM
03-15-2016 10:03 AM
443 TCP, 22 tcp, 91 tcp, 123 tcp, 1812-1813, tcp 23233 udp, 23232 Tcp, 80 tcp, 6868 tcp, 12223 Tcp, 161 Tcp, 21 Tcp, 8080 Tcp, 8443 Tcp, 8099-8111 Tcp, 9997-9998 Tcp, 9080 Tcp, 9443 Tcp, 1143 Tcp, udp, 8090 Tcp, 12223 Tcp, 16384-65000 Tcp.
Additional comment -- if AP was in fact connected to ZD, even after factory reset, when connected to vSCG, it will not work properly. You need to reset it to factory default again after it get's v-SZ firmware, only than it will work properly.
Hope it helps,
Eizens
03-16-2016 04:13 AM
03-16-2016 08:12 AM
LWAPP2SCG is active for all APs.
We configured 03 as well as 06 in DHCP option 43
Here a picture of our configuration:
But it still does not work...
03-16-2016 09:20 AM
