Clients getting frequently disconnected on 2.4GHZ Radio while its is running smoothly on 5GHZ in same network
raazuko
Clients are getting frequently disconnected on 2.4GHZ Radio from R500 while its is running smoothly on 5GHZ in same network.Connected devices would disconnect frequently and new devices hardly get to connect.But no issue in 5GHZ.Any idea on what the issue could be?Also in some old devices with b/g it seems fine.Is there any way to disable n mode in vSZ for 2.4GHZ Radio?
5 REPLIES 5
martin_martin
Valued Contributor
Hi Raju,Your 2.4 Ghz might be a bit full.But first lets start with the software version running on the controller and on the R500.RegardsMartin
raju_koirala
The controller is vSZ running 3.4.0.0.976,thanks
dave_watkins_74
Contributor
Do you have ChannelFly enabled on 2.4Ghz? If so that could be the culprit
raju_koirala
Nope,Its on background scanning.I have disabled band balancing too but no help
Labels
