Changing Ruckus R500 from Smartzone to Zone Director Firmware
matt_hodge_d5fx
Hi - is there a way to change the firmware on an R500 AP from Smartzone to Zone Director?
1 ACCEPTED SOLUTION
ishant_sharma_6
RUCKUS Team Member
Please perform below steps:
1) Perform a f/d on this AP by CLI or physical reset button.
rkscli: set factory
or
On the AP back console using paper clip, press hold the button which says "Hard Reset" within a tiny circular port for about 10 to 12 seconds.
2) Download standalone image :
3) Upgrade using CLI or WEB :
Ishant
4 REPLIES 4
ishant_sharma_6
RUCKUS Team Member
rkscli: set factory
or
Ishant
matt_hodge_d5fx
I'm sorry, my mistake, the APs I'm having a problem with are using the unleashed firmware, not smartzone. Is there a way to change it from unleashed back to Zone Director?
ishant_sharma_6
RUCKUS Team Member
Hi Matt,
For unleashed also you need to follow the same steps.
Just factory default the AP and upload standalone firmware image to AP.
Ishant
Piet
I'm also trying to migrate, in my case a R600 AP, to my Zone Director.
The SID is stuck at the Island state: "island-216c50".
It was suppose to switch to RecoverMe after 30 mins but never switched.
Piet Delaney
