Can we run R610 temporarily on ZD1100 with 9.8.3.0.58 firmware?
newsfool
I know that the R610 is not officially supported on the ZD1100 with 9.8.3.0.58. Does anyone know if it will unofficially work with limitations?
I know that 9.8.3.0.58 supports the R600. I noticed that the R610 will show up in my list of AP's if I add it to the network. I thought that maybe there might be some limited support.
I am in the process of moving from our ZD1100 to vSZ 3.6. I have a large number of R610's sitting around. My vSZ is not live yet, though. I have a limited area where I want to use the R610 for non-critical work before I move to the vSZ controller.
Perhaps it would be best to run it as a stand-alone AP until the vSZ is operational?
Suggestions welcome.
Thanks!
3 REPLIES 3
diego_de_souza
No, its not possible connect a R610 in a ZD1100
ikkifx
newsfool
Thank you, both! That gives me a direction to follow.
