Can the Wifi 6 AP compatible with Wifi 5 ? (Ruckus r750 ---Ruckus r500)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-07-2021 02:11 AM
Hi all,
I am now using normal web page to control our Ruckus Unleashed AP with no any watchdog or central management device.
R500, R510 ,R710 purchase and expand the network at different times.
(A) All my AP wired the network cable to same switch, Should I need e
(B) If I purchase R750 (AX) Wifi-6 to replace my R500 .
Any problem appear to when I add R750 (AX) Wifi-6 into my exiting WIFI-5 (AC)network?
Can I still control all AP in one portal webpage?
Thx all.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-15-2023 09:35 AM
@darrelmay One more thing ... is there a way to just downgrade the R750 to 200.7.10.202.118 ... or is that not the issue anyway?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-15-2023 09:38 AM
@darrelmay Sorry Darrel, mean to tag @karthik . 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-15-2023 10:38 AM
200.7 did not have support for R750. 200.8 is the first version to support R750 as a new AP.
See https://indhradhanush.github.io/rksunlfw/ for AP compatibility with firmware versions.
Karthik.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-15-2023 06:15 PM
@karthik Yep -- understood. There's no versions that overlap between R750 and R500. So, since I don't want to just throw away the R500's ... or limit myself to just R500's given the R750 sitting here, that leaves just the other item:
Am I understanding from what you are saying that I can get the R500 to work if I pull them off ethernet, and let them instead mesh to the R750? Will the R750 still act as master?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-07-2021 05:14 PM
Got it. Thank you darrel , sanjay ,karthik!!!
