Can UNIFI AP Controller work with R300/ R310 AP?
sonny_salmasan
UNIFI Controller and R300 and R310 AP
9 REPLIES 9
hayward_kong
Contributor III
Unifi controller only works with Unifi devices....
Ruckus device can be used with Ruckus controllers, unleashed, or standalone.
thanks a lot.
hayward_kong
Contributor III
If you are looking for a free controller for ruckus without paying license fees, then you'll have to get devices that support unleashed. Just note, R300 does not support unleashed. You would have to stick with R310 or newer... note R310, R500, R600 is only supported until unleashed firmware 200.7.x... R510, R610, R710 are supported with the most current firmware now 200.8.x
sonny_salmasan
We have around 300 R300 & 50 R310. Just needing to know if they will work on other AP controller. Our management is looking for UNIFI im not sure who told them that it would work and can control them like ZD instead of renewing licenses and watchdog. Can you confirm they cant work together?
