COMO PUEDO CARGAR FIRMWARE CON SSH A AP R700. YA QUE AL PARECER NO INICIA CORRECTAMENTE. LED POWER SE MANTIENE PARPADEANDO. GRACIAS
8 REPLIES 8
GOOD MORNING, HOW CAN I LOAD FIRMWARE WITH SSH TO AP R700. SINCE THE LOOKING DOES NOT START CORRECTLY. POWER LED KEEPS BLINKING. THANK YOU
Esteemed Contributor II
Factory default the AP (push indented button for 8 seconds), then try ssh to 192.168.0.1 with "super/sp-admin" credentials.
If using PoE, try using another cable.  AP should show solid power LED after 1-2 minutes.
Thanks I'll try
Por defecto, el AP (presione el botón con sangría durante 8 segundos), luego intente ssh a 192.168.0.1 con credenciales de "super / sp-admin".
Si usa PoE, intente usar otro cable. El AP debe mostrar el LED de potencia sólida después de 1-2 minutos.
