6 APs in an unleashed network, serving up 4 separate SSIDs.
DHCP turned off on Rukus, and managed by non-Ruckus routing infrastructure.
Requirement:
We would like to route for clients that come in on a particular SSID (call this SSID-4) differently. Need to find a way to "mark" those clients on SSID-4 so that the router can do the right things.
One concept we had was for the Ruckus wireless to have DHCP turned on for just SSID-4, and assign IP's in a specific/known range so that the router could treat route these differently.
Question:
Can the DHCP be turned on for just one of the SSIDs?
Can we set the range of IPs that that DHCP serves?
If not, any other ideas for how to "mark" these clients/packets for the upstream router to handle?
Note: We are okay using CLI if that is the only way. Thanks!
Please let us know if this works. Unleashed is not designed for multi-VLAN, only single LAN deployment. Switches assigning VLAN by WLAN priority tag would be a workaround solution.
Ooops! I didn't know that about Unleashed.... Is the ACL available on Unleash? If so, he could simply block traffic from WLAN-4 to the networks he'd like to keep private.
