09-07-2021 01:41 PM
I've tried with the controller and it fails the update to enable PoE on eth0 (interface 1) PoE out interface. Controller successfully updates other settings on same T750. Have tried on 2 brand new T750 APs. I also tried via the CLI and is still failed to set pot out enable.
Have a call into support but waiting for a call back so I thought i woudl also ask here.
09-08-2021 01:20 AM
Hi Eddie,
What power input are you using on the T750?
PoE (PSE) out is only enabled in Max-Functionality full-power mode which is either 57W PoE or 65W AC power.
Thanks,
Darrel.
