11-20-2024 10:54 AM
I have a R710 and a R650 connected to a TP-Link PoE switch SG1016PE.
The Unleashed gui tells me that ‘not enough electricity power’. It was all good before a power outage and now I get that plus the wireless speed in the house had dropped dramatically. I have read I have to switch from auto to 802.3at but I have no clue how and where to try that? Can anyone help with this please.
11-20-2024 11:20 AM
Hello Richard_NZ ,
You could try manually setting the PoE for the access points to the maximum power that the switch can provide to ensure compatibility.
Video Link : https://www.youtube.com/watch?v=hnpSEut96iw
check the Below link :
Power Limitations by PoE Mode and AP Model
11-20-2024 11:20 AM
Hello Richard_NZ ,
12-02-2024 10:05 PM
In my experience, Unleashed has always misidentified the PoE when connected to a PoE+ source. Network equipment should not have an issue detecting that it is connected to sufficient PoE power, especially if negotiating PoE+. If it can't detect the available wattage from a PoE source, it should assume full power until it senses a power issue. When will a fix be released to address this problem with PoE+ APs?
11-20-2024 08:57 PM
Ok - I found a way to do that by following the above advice. Thank you. Now the orange warning triangles have gone. I still have issues and I'll post these in another topic.
