Airprint not working on R500 / R510 unleashed
glenn_james_l2n
Ever since we switched from rubbish consumer WAPs to Ruckus Unleashed (3x R510, 1x R500), I have never been able to get AirPrint working. It used to work fine with the old WAPs but no matter what I do, it just doesn't work with the Unleashed setup. I have read numerous support threads and tried things like bonjour gateway (which I don't think we would need?), made sure client isolation if off etc but it just does not work.
Can somebody help me please? I've setup numerous Wi-Fi network including Ubiquiti Unifi, Netgear, Ruckus ZoneDirector, Meraki, Cisco but for the life of me, I just can't get unleashed to play nicely.
Help!
10 REPLIES 10
hayward_kong
Contributor III
Works for be fine on unleashed 200.6.10.x on a r710.  Only reason I’m not on the newer 200.7.10.x is I find it buggy. I find speed issues on iOS devices on 200.7.10.x ... and I’m not the only one who has this issue on 200.7.10.x. I kept my clients on 200.6.10.x  since they also experienced the same issues on 200.7.10.x.  Ruckus support so far hasn’t acknowledged this issue.
I suggest that you run a speed test on your r510 aps using ruckus SpeedFlex and see what speeds you are getting and see if you are getting extreme slow downloads.
if you are.I suggest rolling back to 200.6.10.x and see if that helps your AirPrint issue too. I just find too many issues with 200.7.10.x since they changed WiFi drivers from what I can tell.
glenn_james_l2n
I have now had a chance to try rolling back to previous firmwares - 200.6.10.1.310 and 200.5.10.0.235 - as suggested here and in another thread and it has made absolutely no difference. I still can't find the printer on my network. Bonjour and Airprint are active on the printer and I Can browse to the printers web interface from the iPad so I know that there is connectivity. AirPrint is just refusing to work.
I'm just about ready to give up this. I'll never buy Ruckus again. I've installed a couple of Unifi networks since and never had any issues like this.
Anyway, sorry you are frustrated, but yeah. Unifi has it's own issues too. Of all the years I have ruckus .....never had airport issues  besides a really bad printer MFP from Samsung which kept crashing.
hayward_kong
Contributor III
Glenn, by any chance did you test the wifi speed? at this point I don't think your AIrprint issue is a firmware issue.  What printer do you have? how is it connected Wifi or ethernet?  What router are you using?
Airprint works fine for me then again I have a HP 426dw
hayward_kong
Contributor III
Also my clients are unleashed 200.6.10.x and don't have issues with airport... varies different printers Canon MF Color Lasers, HPs, Brother printers..  Just wondering what else is on your network? router, switches etc...
