HI Mallikarjun,
All you need is R720 APs with Unleashed firmware and you are good to go.
But we do recommend to purchase the support for Unleashed because, later on if you want to report any issue to Ruckus support and face any issue, support will not be able to help without Unleashed support.
Unleashed support SKU is just a single license you have to purchase and you can connected number of supported AP (per AP license not required).
Please refer below artilce for more info.
https://support.ruckuswireless.com/articles/000005298Regards,
Syamantak Omer
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
