AP r510 remains provisioning
maykeling_romer
Hello, I have an AP r510 installed, the controller recognizes it but it remains provisioning it does not go from there.
10 REPLIES 10
sanjay_kumar
Hi Maykeling,
1. What is the firmware version on the AP and the Controller?
2. Do you enough AP license on the controller?
3. Is the CP and Controller are on same location?
4. Is the Controller and the AP are on same Country code?
maykeling_romer
The ZD 1200 Version is 10.1.2.0 build 251
The AP firmware is 104.0.0.0.1347
Yes, the controller has 10 licenses available
the country code is the same.
How do I see the location?
sanjay_kumar
Hi Maykeling,
About location, I meant if the AP and ZD is on same LAN or connecting via VPN, MPLS or AP is located in remote site connecting via public IP to ZD.
maykeling_romer
The ap is in remote offices, the strange thing is that in the same LAN if it connects perfectly but when I connect it in the remote site it remains provisioning.
