02-03-2025 06:25 AM
Hello, after the firmware upgrade and ZD1200 rebooted, i saw some APs show firmware upgrade and some disconected like a normal upgrade process.
but after 20 minutes the situation did not evolve and all the APs remained disconnected.
I tried to restart an AP manually but it didn't help.
I have three types of APs but they are all supported by the latest firmware update.
I had no choice but to revert to the previous firmware version and all APs reconnected without making any configuration changes in fact I was able to ping all APs from the controller even though they were not connecting.
I have a support license valid until June 2025.
Has anyone encountered the same problem?
02-13-2025 08:42 AM
Same Problem here !!
265 > 279 > None of our 38AP ist found !!
University Campus WLAN is offline
Bad idea to update !
02-13-2025 09:02 AM
We definitely had version 10.5.1.265 installed - but it doesn't seem to exist???
Unfortunately, we no longer have the image and it can't be found in the download area.
We're now trying to go back from version 279 to 276.
02-13-2025 09:58 AM
You can use the following links for all three versions:
10.5.1.0.265
https://support.ruckuswireless.com/software/3752-zd1200-10-5-1-ga-refresh-6-software-release
10.5.1.0.276
https://support.ruckuswireless.com/software/3994-zd1200-10-5-1-ga-refresh-7-software-release
10.5.1.0.279:
https://support.ruckuswireless.com/software/4401-zd1200-10-5-1-ga-refresh-8-software-release
Vignesh
02-13-2025 10:12 AM
Thank you !
Finally I have already found .265 (MR6) in the downloand area and after downgrade to 265 everything works fine ...
Recently:
279 > NO APs found
(Downgrade to) 276 > Still No APs found
(Downgrade to) 265 > Cluster (2x ZD1200) works as before.
Actually we are using 38 APs (R600, R710) and two ZD1200 but all of these devices are have now reached EOL .. know we now why ...
