7351 AP? Im looking for the datasheet!
zack_pittman_74
I know its EOL, but im looking for a datasheet specific to the 7351. All I can find is 7352 and 7300 series, but I would like to know exactly what the 7351 is!
If my googling is up to par, I understand its no POE, and dual band, but is it concurrent?
Any help or lead to a manual or old datasheet would be awesome!
Thanks!
3 REPLIES 3
monnat_systems
Valued Contributor II
ZF7352 got 2 ethernet ports in the back however ZF7351 got 1. this is the only difference
zack_pittman_74
Can you confirm that the 1 port on the ZF7351 is 10/100/1000 POE?
Esteemed Contributor II
The rear panel of the ZoneFlex 7351 features one 10/100/1000 PoE Ethernet port,
power socket and reset button.
https://support.ruckuswireless.com/documents/551-zoneflex-indoor-access-point-9-8-1-user-guide
