Showing results forย
Search instead forย
Did you mean:ย
7321 AP indoor ceiling bracket?
I am trying to figure out, buying a bracket for this, to screw onto a ceiling. Are their different types of brackets available?
2 REPLIES 2
Scott,
take a look here - mounting-bracket-guide
http://c541678.r78.cf2.rackcdn.com/da...
I Don't find anything for ZF7321. If you still fail, please check your regional Ruckus system engineer who can recommend.
When i brought the AP's, the instructions said to use the screws that came with it (it looked like a week setup) or use a T-Bar. Whats a T-Bar?
I found out today its the metal cross-cross on the ceilings in lots of buildings, like ours!
Just use them, anywhere, twist, click, done! Easy. If only i knew that before.
Case closed
