3xR700 speedflex MAX 300mbit on GIGALAN
I have 3 R700 APS with no ZD.
Have tried several sw releases but currently running 100.1.0.0.432 as this has the highest throughput in WIFI and LAN.
running IPERF3 while replacing two APS with PCs give me:
Server listening on 5201-----------------------------------------------------------
Accepted connection from 192.168.100.1, port 37418
[  5] local 192.168.100.69 port 5201 connected to 192.168.100.1 port 23843
[ ID] Interval           Transfer     Bandwidth
[  5]   0.00-1.00   sec  92.3 MBytes   774 Mbits/sec
[  5]   1.00-2.00   sec  97.9 MBytes   822 Mbits/sec
[  5]   2.00-3.00   sec   103 MBytes   860 Mbits/sec
[  5]   3.00-4.00   sec  91.5 MBytes   768 Mbits/sec
[  5]   4.00-5.00   sec  94.2 MBytes   790 Mbits/sec
[  5]   5.00-6.00   sec   101 MBytes   851 Mbits/sec
[  5]   6.00-7.00   sec   102 MBytes   859 Mbits/sec
[  5]   7.00-8.00   sec   101 MBytes   851 Mbits/sec
[  5]   8.00-9.00   sec   103 MBytes   862 Mbits/sec
[  5]   9.00-10.00  sec   103 MBytes   861 Mbits/sec
[  5]  10.00-10.12  sec  10.2 MBytes   739 Mbits/sec
[  5]   0.00-10.12  sec  0.00 Bytes  0.00 bits/sec                  sender
[  5]   0.00-10.12  sec   999 MBytes   829 Mbits/sec                  receivertch and ethernet cables
So, 829 Mbits/sec is fine and I think we can eliminate switch and/or cable issues.
Ruckus is giving me MAX 300mbps using SpeedFlex test (tried several ways with all 3 APS)
ethernetport is configured as trunkport
bridged to WAN
802.1X disabled
option 82 enabled
fingerprinting enabled
giving me a 1000M full in the status view:
LAN Port StatusRefresh
Port  Interface  802.1X  Logical Link  Physical Link      Label
0 eth0 None Up Up 1000Mbps full 10/100/1000 PoE
1 eth1 None Down Down 10/100/1000
is there a setting I`m overlooking to enable full speed between APS?
2 REPLIES 2
