(1) ssid with multiple Vlans
Can I use the same SSID with multiple vlans? It's because we have two buildings and it would be easiest with just the same SSID. It has to be a different vlan because of our firewall.
6 REPLIES 6
Have to rejoin the ssid in order to grab a new address from the new vlan...
I am seeking current information to see if new firmware has altered the settings mentioned in this post.  See also, https://support.ruckuswireless.com/answers/000002234.
If this information in the answers and this forum is correct and current, is this the best way to configure the ZD / ZF?  That is, is this RuckusWireless best practices for use and security of the WLANs?  We would like to use the same WLAN for multiple security groups specific to multiple VLANS but would we be better to use multiple SSIDs long term?????  Especially, if future firmware will no longer support answers#2234.
Thanks in advance for your helps.
