url redirection problem after successful authentication
temur_kalandia
hello ,
i have configured hotspot with AD integration. the problem is that users are not redirected to intended URL, it opens instead http://null page.
authorization process is goes perfectly, if user opens another tab and types the same intended URL , it is accessible perfectly.
so we need to automatically redirect users to intended URL..
also , can you please describe how exaclty goes that redirection process?
regards
3 REPLIES 3
keith_redfield
Valued Contributor II
Hi Temur,
What version of ZoneFlex is running? What is the URL you are trying to re-direct to?
https://support.ruckuswireless.com/an... might help.
temur_kalandia
hi all,
close the topic please... after analyzing debug logs with ruckus support we determined that there is something wrong with our network.
thanks
keith_redfield
thx Temur, will do. Good luck.
Labels
