WLAN(SSID) are visible from other WAN Groups that are not member of the group
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-21-2015 01:39 AM
Ive created 2 WAN Groups and 4 WLANs, then joined 2 WLAN on each WAN Groups but upon verifiying the created WLAN(SSID) are visible on both WAN Group.
3 REPLIES 3
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-21-2015 11:15 AM
Hello Gie,
I'm sorry I can't quite follow you. Do you mean you have created two AP Groups, and you wish to apply the different WLAN Group to each?
From Configure/WLANs, have you setup two WLAN groups, each with the SSIDs you want?
Then from Configure/Access Points, under AP Groups, define a new group (not System Default),
and under Radio Settings, there is a WLAN Group option to "override System Default", which
is a dropdown, and should show the alternate WLAN Group you defined.
If you made two different WLAN Groups, you should be able to assign them to the APs in two
different AP groups, with this override setting. Make the setting on both radios if you have
dual-band radios. I hope this is helpful.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-21-2015 11:48 PM
Hi Michael
Thanks for your reply. I've overlooked to change the 5ghz radio to override to newly created WLAN Group.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-22-2015 10:54 AM
99% of the time, that is the reason
