On a stand alone ZF7363 AP, where can I change the power settings of the radios?
phil_coverdale
On a stand alone ZF7363 AP, where can I change the power settings of the radios? Can the operating country be changed?
1 REPLY 1
keith_redfield
Valued Contributor II
See screenshot. If you don't see the Country Code selector, that is a US only unit and cannot be changed.
Image_ images_messages_5f91c40f135b77e24793fd71_d713d4c7bc1c3befdafcc437b219341e_Ruckus_Wireless_Admin_inline-ab1936a9-4a10-43fa-af3f-d8d1f18e2f3c-2112548207.jpg1392760907
You change the Tx power settings under the Advanced button. Note that default is "full" so you would normally turn it down only when interference is a concern.
