Issue with 9.7 on ZF2942 on ZD controlled AP
drc
Not to hijack, but I have a ZD3100 and 51 2942 APs...and upgraded to 9.7.
Same symptom, connected clients became disconnected clients. Average 300 users total then averaged 51 or so, a LOT of APs have zero clients...oh the horror.
Case opened, but no joy.
Opened forums, I see this, and I downgrade.
CURRENT STATUS: 20 minutes later, am on 9.6.2.0.13, back to high client count, APs have multiple clients.
Case is still open, although I agree with the consensus that the 2942 can't handle 9.7, so perhaps moot.
Just sharing.
Note: This topic was created from a reply on the ZF2942 Upgrade to 9.7.0.0.220 causes problems topic.
3 REPLIES 3
keith_redfield
Valued Contributor II
I forked your comment so we can track this separately. It's probably related to the same issue as the standalone - resource starvation. We've been able to reproduce in-house. Configure a ZF2942 with 1 WLAN - no problem. Configure with 8 - it chokes. We're still investigating whether we can implement a software fix for this.
keith_redfield
In looking through bug details it looks like power-cycling the AP's (maybe after a factory reset) is bringing them back into operation. Had you tried that?
drc
Hi Keith, thanks for the support.
RE: sw fix, 2942 is old, don't support 802.11n, and frankly, I don't think it's worth troubleshooting. Be as it may, I would be glad to apply any fixes team Ruckus comes up with.
As far as power cycling APs after a factory reset, am unable to perform that as both Wi-Fi systems are in production now, and am reticent to upgrade again for the sake of power cycling and factory reset; I'd rather stay here for now.
Labels
