hi would like to ask max horizontal of t300 ap in free space, im currently designing and would like to know effectivity range
ricky_guiang
t300 max range horizontal distance
2 REPLIES 2
alan_rothenstre
Contributor
I have experienced as much as 400 feet and still being able to connect.  It all depends on the environment and RF noise.  Also the channel.  The range is shorter for 5 GHz.
eugene_eusores
No exact distance.It depends on what type of environment the AP will propagate the RF signal, less interference or obstruction the signal will travel longer
Type a product name
