ZD1200 How to kill the bad signal client offline
joe_tommie
if an ap shows the RSSI value of a client is greater than 75dbm, which means signal very bad .
I dont know ruckus production very much , but i want to know how to kill the bad signal client offline , and then make sure that the client can connet the nearest ap when the movable client change its location .
How to set the ZD1200 , which can automatically implements the function .
5 REPLIES 5
sanjay_kumar
Hi Joe,
Below article explains about the table mapping the Roamfactor value to the SNR. Please check for your reference.
https://support.ruckuswireless.com/articles/000002637
Sanjay Kumar
