What is included in "Miscellaneous" and "Others" usage of applications?
kenny_renoult
Is there a list of applications which are included in theese categories?
1 REPLY 1
jay_files
Contributor
Those are the applications that ZD is unable to identify with the built-in application recognition engine. If you have applications that you know, but are not properly recognized, then you can create customized applications using the ZD "User Defined Applications" settings. You can create either port-based or IP-based applications.
Please refer to the ZD User Guide for more info.
Cheers,
Jay
