I got a ZoneFlex 7982 from my work and I'm kind of new at this. I connected the 7982 to my router and configured two SSID (2.4 & 5GHz), on the 2.4GHz network I didn't set any encryption method and yet that SSID it's using my router's WAP2 password but if I set the 5GHz with no encryption it doesn't do the same. What I can I do so the AP recognizes both networks as one.
Ps. If I search for networks the 2.4GHz it's showing router and AP as one but 5GHz are two different networks.
