Ruckus Ap configuration without controller
user_unix
Hey Everyone, I want to ask if is there any windows logiciel to configure Ruckus Ap without controller. And Thanks.
7 REPLIES 7
Anusha_Vemula
Community Manager
Community Manager
Ruckus APs can also be configured in standalone mode without controllers. However, they should have a standalone firmware running on them.
You can download the firmware from our support site using below link based on the AP model you have.
https://support.ruckuswireless.com/software
Anusha
and how can you update the Firmware without a controller. Like for example I have 30 APs do I need to update each one manually? is there a way to update them once?
I have the same issue and no one has been able to give a answer.  Most of the solutions they give me is to reset them but you can’t ssh in or telnet in
