Printer "unauthorized" on WLAN
michael_grant_6
Contributor II
I am trying to connect a HP OfficeJet 8600 to an encrypted WLAN. I get a connection error on the printer:
"Unable to connect to the network."
WLAN is on VLAN1 and all other clients connect and authorize fine.
SSID authentication: open
Encryption: WPA2
Algorithm: AES
ZD (9.8.2.0 build 15) shows printer as unauthorized. Printer will connect fine to an open encryption SSID.
Image_ images_messages_5f91c3de135b77e2478be542_4c31f5b606e888607805e62e400278e1_RackMultipart2015051832165hjma-82db6448-1a2f-4b97-a71e-9b15b5022949-929771922.png1431974390
14 REPLIES 14
daniel_m
Contributor II
You might want to try updating the firmware on your printer.
michael_grant_6
Contributor II
It is on the latest firmware/software.
Esteemed Contributor II
Sure the radio is turned on?  Setup>Network>Wireless - On/Off?  Is the 802.11 LED on?
Does the printer support WPA2?  You may need to use WPA with Auto for WLAN policy?
http://h10032.www1.hp.com/ctg/Manual/c03026243.pdf
michael_grant_6
Contributor II
Wireless is on and is currently connected to a seperate WLAN unsecured, this is the only way to print wireless right now. The printer connects fine to an Apple AirPort with the same SSID and WPA2 password.
