01-04-2024 04:36 AM
I'm helping to build a WiFi network in a school (using h320 / h510 / r510 / r610 / r710 / t310 / t610) in a pretty big area. All AP should be connected by 1Gb PoE ethernet (2 big switches with 10Gb uplink). All L3 features like routing should be processed on a separate gateway that is connected by 10Gb.
Can enabling Mesh increase redundancy without side effects?
I hope I understand right:
In other words, it will be like switches with STP over air instead of ethernet.
However, I'm not sure if mesh can bring advantages as losing connection with a switch means losing PoE power and the switch will have double uplinks.
01-10-2024 10:54 AM
Hello @namezys,
AP's mesh link is not a replacement for the SW to SW connectivity because with each AP mesh hop, bandwidth will be reduced by two. Not just this, overall speed also depends on how strong signal both AP receive, thus with poor signal strength between mesh APs will further degrade the overall speed behind the mesh AP network.
Using mesh is fine, but running a large network behind a mesh AP depends upon how big is the network and how much bandwidth is required.
I hope this answers your query.
01-11-2024 02:57 AM
Yes. As I expected.
In other words, if all wire connection works fine, mesh will not used.
To be honest, I realised that with PoE switches it's useless for me as broken switch means no power for all AP.
01-10-2024 10:54 AM
Hello @namezys,
01-11-2024 02:57 AM
Yes. As I expected.
01-11-2024 06:26 AM
Let us know if you have any additional queries, if not, please hit the Kudos button and accept the answer as Accepted solution.”
