Mesh APs keep changing IP address and show as down in my network monitoring software, can I configure 2 IP on the APs
eddie_sanmarco
Mesh APs change IP and get marked down in network monitoring applications
2 REPLIES 2
Esteemed Contributor II
First question is why are your mesh APs are going down?
Then why would yhey receive a different (DHCP assigned?) IP address?
eddie_sanmarco
They aren't "going down" they are meshing to another root AP in teh area due to probably better signal quality at that moment and my management software is marking it down because it is modeled by the original IP address. The other root AP is on another subnet.
