Is compatable the SCG version 2.5.0 with 2.5.1 AP firmware in SCG?
theint_theint_e
I want to know SCG version 2.5.0 can control T300 AP firmware 2.5.1 or not?
Because T300 model SCG version lowest is 2.5.1 but our SCG version is 2.5.0.
Please reply to me hurry.
2 REPLIES 2
rob_krumm
Hi Theint,
The SCG using 2.5.0 will NOT be able to control a T300 running the 2.5.1 firmware.  I would advise you to upgrade your vSCG to the latest 3.0.4 code release available on the support site.
This code release will require you to create a NEW VM instance and migrate any of your configurations and licenses across.  Please contact your local partner or support if you require assistance.
Esteemed Contributor II
