Cisco ISE and Ruckus
bruce_richards1
I'm in the planning stage of rolling out Cisco Identity Services Engine v2 , we already have Ruckus WiFi connected to Zonedirector ZD3050. I've found the Cisco documentation, but it only really mentions Ruckus in passing.
http://www.cisco.com/c/en/us/td/docs/security/ise/2-0/release_notes/ise20_rn.html#29472
Is Ruckus supported out of the box or will I need to create a custom profile ? The documentation is a bit ambiguous on this.
http://www.cisco.com/c/dam/en/us/td/docs/security/ise/how_to/HowTo-105-Network_Access_Device_Profile...
What functionality can I expect from this integration between the products?
Anything else I really need to know ?
Thanks for reading.
Bruce
2 REPLIES 2
Esteemed Contributor II
I haven't seen much interoperability with Cisco ISE documentation... so you may need to contact your local Ruckus SE for assistance.
scott_gribben
We have also been waiting quite some time.  Don't understand the delay in getting this into the product sooner, rather than later.  We have integration projects on hold for Cisco ISE and Ruckus VsZ that we cannot execute on because the feature (URL redirection) is missing from the controller software.
