Showing results forย
Search instead forย
Did you mean:ย
Change IP of AP on Unleashed network
c_thomas
I recently added a new R710 to my unleashed network. It still had ZD installed when I got it so I connected via ethernet and updated it to Unleashed. No problem. When the AP came back up it grabbed a DHCP address from my network and joined the my Unleashed network.
I don't really want the AP in my DHCP pool and would prefer to assign it a static IP. I don't see anyway to do that via the Unleashed web interface. If I try to connect to that AP directly it just redirects me to the Master AP. Is there anyway to change the IP of the new AP?
1 ACCEPTED SOLUTION
david_black_594
Contributor III
Select Access Points, select the R710, up at the top click Edit, a window for the R710 will appear, click the Network tab, click Manual
3 REPLIES 3
david_black_594
Contributor III
I feel stupid now. ๐Ÿ™‚
Thank You.
@c_thomas  You're very welcome, and don't feel bad about it.  We've all been there. On products that Ruckus tries to "simplify" for non-technical end users, they hide or obscure things that the rest of us need.
