Captive portal redirection issue
di_support
Client connected to the SSID, gets the DHCP config but no captive portal redirection for the username/password, hence no internet access. Manually typing the url of the captive portal/ZD works fine.
Any ideas?
Cheers
7 REPLIES 7
yuval_ben_ari_6
Which controller / AP's are you using?
di_support
Hi Guys,
Raised the case with Ruckus. Resolution below:
- the controller was previous running on 9.6 version and now running on 9.8 version. There is a known software bug on the ZD which are upgraded from 9.6 to 9.8.
- TAC engineer went into the ZD shell mode and applied the fix on the necessary files (added missing firewall rules)
-  rebooted the controller
- redirection started working
Thank you all for your input on this.
@di_support What were the firewall rules that you added? I'm running into the same problem.
