I'm doing a WiFi setup where everything's handled, the APs are set to IPv4 Static, and the primary/secondary DNS fields are blank.
When I configure them this way on the web, the blank fields are accepted. But if I try modifying the APs to static using the API, I get this message:
{"message":"network.primaryDns is invalid IP address","errorCode":302,"errorType":"Business rule violation"}
Tried using a blank string, and then tried a null value for the primaryDns and secondaryDns, didn't manage to get either working.
Any ideas?
