ZoneFlex R310 Radius Configuration/Speed Issues
We have five ZF R310 Unleashed WAPs in our environment in a mesh. Currently I have two wireless networks, one running WPA2 and the other using Radius.
I am using local Windows server CA and Radius (NPS). This is all on the same local LAN under the same subnet.
I have been able to get Radius authentication to work, but the speeds are extremely poor using Radius authentication. I expected some slowdown, but we are looking at speeds of 50 up/down for WPA2 and 0.1 up/down for Radius.
I haven't set up a Radius server before using Windows nor have I used Ruckus for Radius authentication. I don't know if this is a limitation of our hardware or if this is misconfigured.
Are there any Radius guru's out there that might be able to shed some light on this? I'm willing to post non-identifying configuration information at your request.\
Thanks in advance!
6 REPLIES 6
Correction... it looks like the 200.6 software has been released and should already contain the patch for this. I'll be upgrading the firmware and testing.
Confirmed this was the issue, everything is working now with loss of speed only about 10% now. Some reduction in speed was expected, and this is inside of the window we expected.
Hope this helps someone else.
