08-18-2023 07:04 AM
I have tried resetting the ruckus by unplugging and restarting, but it still won’t show up in the network ID options to select from. How do I get this device to work again? All the lights are green on it but it’s not connected??
09-10-2023 07:27 PM
Did you find an answer this product sucks same issue. No one to talk too to fix
09-10-2023 08:06 PM
Hi @Jon
I believe you tried doing the reset by pressing the rest button for 10 seconds.
Once done, the AP will broadcast the new SSID "Configure.me" SSID.
If you see it, then you can connect to the AP and configure using the below method:
From Mobile or Laptop:
1. Connect to the SSID "Configure.me" SSID.
2. Open the Browser and type https://unleashed.ruckuswireless.com Or use default AP's IP https://192.168.0.1
3. Then you can proceed to configure the setup.
If you are not seeing the Configure.me SSID
1. Connect the Laptop to the switch where the AP is connected.
2. Make sure the Laptop IP subnet is on the AP subnet range (Example 192.168.0.10)
3. Make sure you can ping the AP's IP 192.168.0.1
4. Open the browser use https://unleashed.ruckuswireless.com Or use default AP's IP https://192.168.0.1 to connect to the AP.
Let me know if this works.
