03-28-2026 12:53 PM
This literally means it works only per AP, not per network. If I have several APs on the same Unleashed, does it mean that traffic from client1 on AP1 won't be isolated from client2 on AP2? And clients are roaming. Then this rule makes little sense. Am I misunderstanding it?
03-30-2026 11:56 AM
Hi @Alleprt
Thank you for reaching out to the RUCKUS Community Forums and for the detailed explanation, that is very helpful.
Based on the information provided, it appears that you need assistance in knowing wireless client isolation from other clients on same AP.
This is a common point of confusion in Unleashed.
Your understanding is actually correct for that specific setting.
The option “Isolate wireless client traffic from other clients on the same AP” works only at the individual AP level. So clients connected to different APs (even on the same SSID/VLAN) can still communicate with each other.
Refer article link below:
https://unleashedsupport.ruckuswireless.com/articles/000001388
Because of that, in a multi-AP environment with roaming clients, this option can feel limited.
If your goal is to isolate clients across the entire network, you’ll want to use:
“Isolate wireless client traffic from all hosts on the same VLAN/subnet”
This enforces isolation network-wide, regardless of which AP the clients are connected to, and works correctly even during roaming (you can whitelist gateway or required devices as needed).
In short:
Hope this helps clarify.
Thank you again.
If your issue has been fully addressed, please click the Kudos button and mark the responses as an Accepted Solutions.
RUCKUS | Community Forums Support
