Instable WIFI connections with Android devices
We have 3 R500 Unleashed. Running 200.5.10.0.283.
We suffer from very unstable WIFI connections from Android devices. The devices range from Samsung Tab S2, S7 Edge, Moto 4G, HTC U11 life.
When I download the logcat from a device and filter on wpa_suppliment I see the following message ‘wpa_supplicant: wlan0: CTRL-EVENT-DISCONNECTED bssid=xxxxx reason=6.’ It is always reason 6.
a logcat fragment
11-30 07:00:19.131  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-DISCONNECTED bssid=f8:e7:1e:87:25:4c reason=6
11-30 07:00:19.135  1993  1993 E wpa_supplicant: nl80211: Failed to open /proc/sys/net/ipv4/conf/wlan0/drop_unicast_in_l2_multicast: No such file or directory
11-30 07:00:19.135  1993  1993 E wpa_supplicant: nl80211: Failed to set IPv4 unicast in multicast filter
11-30 07:00:49.685  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=DE
11-30 07:00:53.068  1993  1993 I wpa_supplicant: wlan0: Associated with f8:e7:1e:87:25:4c
11-30 07:00:53.071  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
11-30 07:00:53.077  1993  1993 I wpa_supplicant: wlan0: WPA: Key negotiation completed with f8:e7:1e:87:25:4c [PTK=CCMP GTK=CCMP]
11-30 07:00:53.077  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-CONNECTED - Connection to f8:e7:1e:87:25:4c completed [id=0 id_str=]
11-30 07:12:49.285  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-DISCONNECTED bssid=f8:e7:1e:87:25:4c reason=6
11-30 07:12:49.287  1993  1993 E wpa_supplicant: nl80211: Failed to open /proc/sys/net/ipv4/conf/wlan0/drop_unicast_in_l2_multicast: No such file or directory
11-30 07:12:49.287  1993  1993 E wpa_supplicant: nl80211: Failed to set IPv4 unicast in multicast filter
11-30 07:12:49.614  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=DE
11-30 07:12:52.992  1993  1993 I wpa_supplicant: wlan0: Associated with f8:e7:1e:87:25:4c
11-30 07:12:52.995  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
11-30 07:12:53.007  1993  1993 I wpa_supplicant: wlan0: WPA: Key negotiation completed with f8:e7:1e:87:25:4c [PTK=CCMP GTK=CCMP]
11-30 07:12:53.007  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-CONNECTED - Connection to f8:e7:1e:87:25:4c completed [id=0 id_str=]
11-30 07:17:02.515  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-DISCONNECTED bssid=f8:e7:1e:87:25:4c reason=6
11-30 07:17:02.517  1993  1993 E wpa_supplicant: nl80211: Failed to open /proc/sys/net/ipv4/conf/wlan0/drop_unicast_in_l2_multicast: No such file or directory
11-30 07:17:02.517  1993  1993 E wpa_supplicant: nl80211: Failed to set IPv4 unicast in multicast filter
11-30 07:17:02.815  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=DE
11-30 07:17:06.219  1993  1993 I wpa_supplicant: wlan0: Associated with f8:e7:1e:87:25:4c
11-30 07:17:06.222  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
11-30 07:17:06.238  1993  1993 I wpa_supplicant: wlan0: WPA: Key negotiation completed with f8:e7:1e:87:25:4c [PTK=CCMP GTK=CCMP]
11-30 07:17:06.238  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-CONNECTED - Connection to f8:e7:1e:87:25:4c completed [id=0 id_str=]
11-30 07:29:06.267  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-DISCONNECTED bssid=f8:e7:1e:87:25:4c reason=4
11-30 07:29:06.269  1993  1993 E wpa_supplicant: nl80211: Failed to open /proc/sys/net/ipv4/conf/wlan0/drop_unicast_in_l2_multicast: No such file or directory
11-30 07:29:06.269  1993  1993 E wpa_supplicant: nl80211: Failed to set IPv4 unicast in multicast filter
11-30 07:29:06.348  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=DE
11-30 07:29:09.721  1993  1993 I wpa_supplicant: wlan0: Associated with f8:e7:1e:87:25:4c
11-30 07:29:09.724  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
11-30 07:29:09.733  1993  1993 I wpa_supplicant: wlan0: WPA: Key negotiation completed with f8:e7:1e:87:25:4c [PTK=CCMP GTK=CCMP]
11-30 07:29:09.733  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-CONNECTED - Connection to f8:e7:1e:87:25:4c completed [id=0 id_str=]
11-30 07:31:56.055  1993  1993 I wpa_supplicant: wlan0: WPA: Group rekeying completed with f8:e7:1e:87:25:4c [GTK=CCMP]
11-30 07:43:14.291  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-DISCONNECTED bssid=f8:e7:1e:87:25:4c reason=6
11-30 07:43:14.293  1993  1993 E wpa_supplicant: nl80211: Failed to open /proc/sys/net/ipv4/conf/wlan0/drop_unicast_in_l2_multicast: No such file or directory
11-30 07:43:14.293  1993  1993 E wpa_supplicant: nl80211: Failed to set IPv4 unicast in multicast filter
11-30 07:43:14.596  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=DE
11-30 07:43:17.973  1993  1993 I wpa_supplicant: wlan0: Associated with f8:e7:1e:87:25:4c
11-30 07:43:17.977  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
11-30 07:43:17.996  1993  1993 I wpa_supplicant: wlan0: WPA: Key negotiation completed with f8:e7:1e:87:25:4c [PTK=CCMP GTK=CCMP]
11-30 07:43:17.996  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-CONNECTED - Connection to f8:e7:1e:87:25:4c completed [id=0 id_str=]
11-30 07:47:27.346  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-DISCONNECTED bssid=f8:e7:1e:87:25:4c reason=6
11-30 07:47:27.347  1993  1993 E wpa_supplicant: nl80211: Failed to open /proc/sys/net/ipv4/conf/wlan0/drop_unicast_in_l2_multicast: No such file or directory
11-30 07:47:27.348  1993  1993 E wpa_supplicant: nl80211: Failed to set IPv4 unicast in multicast filter
11-30 07:47:27.651  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=DE
11-30 07:47:31.032  1993  1993 I wpa_supplicant: wlan0: Associated with f8:e7:1e:87:25:4c
11-30 07:47:31.035  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
11-30 07:47:31.050  1993  1993 I wpa_supplicant: wlan0: WPA: Key negotiation completed with f8:e7:1e:87:25:4c [PTK=CCMP GTK=CCMP]
11-30 07:47:31.050  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-CONNECTED - Connection to f8:e7:1e:87:25:4c completed [id=0 id_str=]
11-30 07:57:49.730  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-DISCONNECTED bssid=f8:e7:1e:87:25:4c reason=6
11-30 07:57:49.731  1993  1993 E wpa_supplicant: nl80211: Failed to open /proc/sys/net/ipv4/conf/wlan0/drop_unicast_in_l2_multicast: No such file or directory
11-30 07:57:49.731  1993  1993 E wpa_supplicant: nl80211: Failed to set IPv4 unicast in multicast filter
11-30 07:57:50.056  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=DE
11-30 07:57:53.434  1993  1993 I wpa_supplicant: wlan0: Associated with f8:e7:1e:87:25:4c
11-30 07:57:53.437  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
11-30 07:57:53.453  1993  1993 I wpa_supplicant: wlan0: WPA: Key negotiation completed with f8:e7:1e:87:25:4c [PTK=CCMP GTK=CCMP]
11-30 07:57:53.454  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-CONNECTED - Connection to f8:e7:1e:87:25:4c completed [id=0 id_str=]
11-30 08:02:02.784  1993  1993 I wpa_supplicant: wlan0: CTRL-EVENT-DISCONNECTED bssid=f8:e7:1e:87:25:4c reason=6
11-30 08:02:02.785  1993  1993 E wpa_supplicant: nl80211: Failed to open /proc/sys/net/ipv4/conf/wlan0/drop_unicast_in_l2_multicast: No such file or directory
11-30 08:02:02.785  1993  1993 E wpa_supplicant: nl80211: Failed to set IPv4 unicast in multicast filter
1 REPLY 1
