12-09-2020 03:49 PM
I have taken the plunge on an R710 Ruckus AP as I understand them to be the best AP's for keeping things working in signal dense environments.
I intend to use it to create a WLAN that extends my wired LAN which connects lots of equipment on a cart thereby enabling wirelessly connected devices like iPads and Cameras to interface with the equipment on the cart. (equipment on cart running with fixed IP's). The cart itself travels with me to studios and various filming locations all over the place, where sometimes the RF environment is very crowded. Since the main purpose of the WLAN is to allow items of equipment on site to talk to each other it is not necessary to connect the network to the internet, although it may sometimes be desirable. If I am to do this I would be using either the internet access available locally via wifi, whatever that might be, or using my phone as a hotspot. There may be situations where I would allow other users on site onto my network but I would want to be able to control the bandwidth allocated to them to ensure vital equipment is prioritised, and control if they are able to use the internet and limit sites and bandwidth there (so I don't run up a massive phone bill if I'm using my phone as a hotspot). On occasion I may need to extend the range of the WLAN by adding further APs in a mesh, ideally deploying them with no physical cabling, just an AP on a stand with a battery for power.
Because of that final point (expandability of the WLAN) I thought Unleashed looked like the way to go rather than Solo. - Perhaps those with more knowledge of Ruckus can give their opinion on the suitability of Unleashed to my application, and if there are any gotchas I might find in my use case?
I would also really appreciate any technical setup advice. I have a switch in my cart, have assigned fixed IP's to my equipment onboard but not much else.
My R710 is currently stuck in a "building unleashed" loop, I think because I don't understand how I should configure the gateway when there currently isn't one to point it at but it's a field you can't leave blank so....In this kind of use case should I be configuring the R710 as a Gateway and DHCP server? Does Unleashed expect to be connected to the internet for set up and configuration?
If the WLAN and LAN have to be on different subnets (I read this somewhere, I think in the troubleshooting guide for unleashed) then what do I need to configure it so that a device on the WLAN can connect to a device on the LAN subnet via it's IP? Will the R710 resolve the addresses automatically?
When it comes to connecting it to the internet on location:
I believe I might be able to use internet sharing on my Mac, which lives on the cart and can be connected to the internet via local wifi then connected via ethernet to the R710? If so, how would I need set this up to get it to work? When there is no local wifi for internet access, how might I go about using my phone as a hotspot to make internet available on the R710s WLAN? Is there a way to make this all fairly plug and play so I don't have to reconfigure lots of settings for each new physical location I take the cart to? For example, if the Mac computer on the cart is sharing it's internet connection, however it gets it (tethering to my phone or connecting to the local wifi), can everything else stay the same?
Sorry for such basic questions, I guess I'm still at networking 101 stage, but most guides on networking seem to assume fixed location installs with permanent internet connections. They also often launch straight into technical language and brush over concepts none of which I am properly versed in yet.
01-08-2021 05:15 PM
These are not basic questions. Well done with getting things as far as you have.
Your "cart" network is no different than any network. It can be one switch with one gateway to the Internet. It can be many switches, routers, firewalls, access points (APs) ... all connecting to the Internet out multiple paths.
It sound like your key question is how to NOT change the Ruckus configuration and still allow those APs to get out to the Internet.
If the gateway or router (GW) you use on the cart is permanent, you should use that as the GW for the Ruckus (or any other) device. That way, if you're routing from that GW to the Internet, you can add a route to to whichever device is providing outbound Internet. For instance, if you have WiFi capability on the router, and you're not wired to the Internet, you can connect to your phone hotspot.
Anyway, this all sound very cool. Sorry I was talking in such general terms.
Thanks.
Doug
02-11-2026 06:55 AM
Thanks Doug,
I think you just about nailed the key question at the heart of my long, rambling post and general terms explanations were just what I needed at this point in time. Sorry it took such a ridiculously long time for me to get back to this post and topic again.
As you say, the key is having a gateway or router with the correct settings sitting at the heart of my cart. My challenge really is in navigating all of the tech terms, understanding the relevant features and being able to use that knowledge to help identify a suitable one to buy.
I'm running a very compact, portable setup that needs to minimise power demands as it has to be able to operate off batteries in remote locations. For this reason it would be great to be able to have an all in one device that can act as the router/gateway, provide POE, and has an external antenna connection that I could feed out of the box and connect to local wifi through - automatically routing to that as the gateway to the internet and managing multiple passwords for all the sites I usually visit by itself. When I need a faster, hardwired connection for uploading, a spare (ideally 10Gb) ethernet port should allow for routing through that port to the internet via the local wired network. Ideally I would be able to prioritise this wired port as a primary gateway, and set the onboard wifi connection as a fallback - turning off the wifi antenna when the wired connection is in use so I'm not adding to the local wifi signal density unnecessarily. Is this kind of functionality present in any router/gateway devices? If so, is it a feature-set with a name that I can use to search for and find products?
These probably aren't common features for equipment commonly intended to sit in a fixed location, but at least, quick and simple access to manually change these settings with minimal fuss would be really helpful and I'm sure that the accessibility of these settings will vary a lot. Maybe some devices will even let you program the relevant settings, enabling the possibility of setting up some kind of automation if none is already built in.
If nothing quite like it exists, then I guess a secondary wifi AP might be necessary, frustrating my desire to keep things ultra compact and also increasing power demand. I think I understand that, basically, I would plug this into a port on the router/gateway, connect to local wifi via it, and target it's IP as my gateway to the internet. I would want that wifi AP to maintain a list of networks and passwords and allow autoconnection to known networks, including my phone hotspot, speeding up my setup time as I move between known locations.
If I want to hardwire into the local network, instead of plugging the wifi AP into my router I can leave that out and use that same physical port on the router in my rig to connect it to the local physical network and then set whatever device it connects to via that port as the IP for the gateway to the internet. (Question here: is this essentially what a home router does automatically with it's WAN port and is there a name for a feature like this, maybe that I can just assign in the router UI?)
Many thanks for taking the time to read this, if you have.
Kind regards,
Quentin.
