I have a mm2211 model ap with customized firmware. I am unable to manage the ap.I successfully connected a serial console to it. Need help for flashing original firmware via tftp.
The process is the same to reset a Ruckus mm2211. If you have a Tikona or custom OEM AP, the administrative login credentials will not be the same as Ruckus.
