upgrade firmware via tftp in mm2211
shailrndra_parm
I have a mm2211 model ap with customized firmware. I am unable to manage the ap.I successfully connected a serial console to it. Need help for flashing original firmware via tftp.
22 REPLIES 22
Esteemed Contributor II
Sorry Shailrndra, if the fw is customized, it was OEM'd by an ISP and Ruckus cannot help modify the configuration.
shailrndra_parm
No problem.
But when i download ftp://ftp.ruckuswireless.com/downloads/support/2211_4.4.2.0.79.BL7 it shows a error 550 failed to change directroy.
So please provide firmware only.i
Ah, the filename has a little "L" not Caps.
ftp://ftp.ruckuswireless.com/downloads/support/2211_4.4.2.0.79.Bl7
You might need to edit the fwcntrl_mm2211.rcks file if it has a big "L" in the filename.
shailrndra_parm
Thankyou sir for such a good support. Happy with ruckus support.
khalid_lakhani
@Michael Brado,
How do i use tftp to flash mm221?
please share, thank you
