Showing results forย
Search instead forย
Did you mean:ย
upgrade/downgrade from fsi to ui is not allowed
What that means this warning?
10 REPLIES 10
Esteemed Contributor II
Where do you see this warning?
On the AP when I'm trying to do the firmware upgrade
Noticed this if you are going to SZ3.6.1 to Solo firmware 100. Change to the new (ish) 104.X.XXXX Solo firmware and it should work.
Kind regards
Gareth
Upgrading from 3.x to 104.x worked, when I tried to upgrade to SZ to ZD directly showed this message
