Showing results forย
Search instead forย
Did you mean:ย
We were without lectrical power for 5 hours, and when it came back we have all AP showing recover.me ssid.
Good afternoon. We are running a network using ZD1200. We were without lectrical power for 5 hours, and when it came back we have all AP showing recover.me ssid. We have restarted Ruckus several times, without success. What should we do?
1 REPLY 1
the ssid recover.me is active when the gateway is unreachable.
is the normal ssid up and running?
if not, is the ZD1200 up and running. can you configure it or is the status led steady green?
if not, you should get the ZD up.
if yes, can you administrate the  AP's? are they in the same network like the ZD?
are some managable Switches involved? VLAN?
for example, the managable switch from zyxel looses the configuration after power loss if not saved before.
good luck
