R500 APs port flapping on Cisco Switch
I have 4x R500 APs with a 1200 Zone Director on version 9.13.3.0 build 22. The APs are connected to a Cisco WS-C2960X-48LPS-L POE switch on version 15.2(2)E6.
The issue is that the 4 ports that these APs are connected to randomly go down throughout the day as shown here:
Mar  1 13:03:43: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/3, changed state to down
Mar  1 13:03:47: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/3, changed state to up
Mar  1 13:03:49: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to up
Mar  1 13:04:14: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to down
Mar  1 13:04:15: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/3, changed state to down
Mar  1 13:04:18: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/3, changed state to up
Mar  1 13:04:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to up
The AP themselves do not show as rebooting but I have verified that users do lose connection when this happens. I cannot reproduce the issue and I cannot find any sort of pattern. Some days one of the ports will not drop at all but the other 3 will. Or some days it might be only one or 2 that drop randomly.
I have verified the cabling multiple times, I even pulled out brand new patch cables and used them and still get the same result. I tried moving one of the APs to an older cisco switch and left it there for a day and it did not drop at all. So that would leave me to believe it's something on that switch itself but I can't seem to track it down. There are no POE events on the switch when a port goes down. I also have other POE devices (mostly phones) that are plugged into the same switch and do not have an issue.
The only thing that stands out to me is that there are a lot STP topology changes on the AP VLAN that originate from the switch ports that the APs are connected to and they line up with when the switch ports drop but I'm not sure if that's a cause or effect of the ports dropping. I originally had spanning-tree bpdu guard and loop guard configured on the ports but I removed them from half of them but there was no change in behavior.
I did open a case with Ruckus support and they looked at the logs and said they see nothing on their side that would cause this. I'm hoping someone else has run into this issue.
Any help would be appreciated as I'm starting to run out of ideas of where to look.
Thanks!
9 REPLIES 9
Esteemed Contributor II
Scott, I don't have a SmartNet contract to view the bug info.  Can you please copy/paste it for us here?
I'd like to capture it in a knowledge article.  Thanks!
Hi Michael,
Here you go:
"EEE" on 2960X and PD device causing intermittent link flapCSCus35889
Symptom:
Dec 30 03:34:54: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/26, changed state to down
Dec 30 03:35:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/26, changed state to up
Dec 30 03:49:50: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/26, changed state to down
Dec 30 03:50:00: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/26, changed state to up
Line protocol flapping, some times with link up/down also, which would cause PDs like AP disconnected/reboot.
Conditions:
When "Energy-Efficient Ethernet" feature enabled on both Catalyst 2960X switchport and on the PDs.
Affected images:
c2960x-universalk9-mz.152-2.E.bin
c2960x-universalk9-mz.150-2.EX5
Workaround:
Disable Energy-Efficient Ethernet (EEE) by below CLI command:
2960X(config-if)#no power efficient-ethernet
Thank you very much, Scott.
To. Michael.
You can find details w/o login on above URL.
https://quickview.cloudapps.cisco.com/quickview/bug/CSCus35889
And plz upload artical for this issue on KB.
I have experienced this issue recently too.
Regards.
Thanks Scott, we faced same problem but our poe switch is Cisco small business SG300-28PP. "no eee enabled" on switch port solved ports flapping.
Thanks all, KBA-6303 will appear tomorrow.
