Many Static Public Ip's on Virtual Interfaces
etienne_bt
Hi guys,
I would really appreciate if you could help me on this, I have a D-Link DIR-686L router with DD-WRT installed on it.
I aslo have a block of 29 public static ip from my isp.
What I actually want to archive is to create many ssid with each of them sharing one of my public static ip's.
Basically, I want to create many virtual Interfaces with dd-wrt and give them each a different ip.
I red a lot on the subject but I didn't found anything fitting my need.
I've seen a tutorial on how to create one ssid and then associate each static ip to a local ip or a mac address. This is not what I want to archive but this is a beginning, I guess.
Here is the link if that could help you to solve my request.
https://www.techenclave.com/community/threads/multiple-public-ips-with-one-router-using-dd-wrt.37283...
Thank you very much in advance. This is something very important for me and I spent a lot of time looking for a way to do that without success, you guys are my last hope!
2 REPLIES 2
Esteemed Contributor II
Many ISPs only provide 1 public IP address, into the WAN port of a customer's home router,
and you can perform NAT for a different subnet on the Ethernet LAN, and on a Wireless LAN (SSID).
A Ruckus AP in Standalone Mode could provide this type of way for you to have multiple Internal Networks,
that be can be NAT routed out the WAN.  Up to 4 Internal Networks, with DHCP, could service 4 networks
(combination of other Eth ports, or different WLAN SSIDs), using the Internal networks, and be NAT routed
out your WAN to the Internet.
Otherwise, without router/LAN switches for VLAN, I cannot imagine how to use/segment your 29 ISP IPs.
alia_bulter
To be honest it is pretty difficult to hunt down this question I read the whole tutorial but didn't get how it is possible multiple ssids sharing your ip without VLAN. Still, hope you managed to do it!
web link
